Greetings!
I'm about to start on my Milano Verde's engine rebuild. I'm preparing to get the engine onto the stand. Before I pull the flywheel off, do I have to mark the flywheel relative to the crank, or are the bolts spaced in such a way so that the flywheel can only go on one way? The shop manual isn't clear on that point.
Also, any good recommendations for a good place to get the heads done in the L.A. area?
Thanks in advance.
Thanks!
The engine will have 10:1 compression when it's done.
I tried to get the flywheel bolts loosened yesterday, but they're frozen. I tried over 300 lb-ft of torque to knock them loose, but they won't budge. Time for more drastic measures.
They should have some strong (red) thread locker on there, try heat to break the bond.
Kevin
I did. Got the area literally smoking hot. No luck. My impact gun made no difference. I have the bolts soaking in Kroil. It's gone down into the spaces really well, so that might help.
