Hello guys
i wanted to know if anyone had any suggestions on this.
The trim piece that surrounds the vent window was in bad shape and thinking it was stainless steel i started polishing it.
After a bit a yellowish/brass finish started showing up. I wanted to know if it needs to be re coated by a shop or maybe since its a small piece I could fint an aluminum type paint i can apply.
thank you have a safe weekend
1617109
1617110
1617111
Antonio,
I do believe that part is chrome plated steel and not stainless steel. It appears that you're polishing through the nickel and down to the brass or copper.
I think it's time to locate your favorite plating shop. Good luck.
im trying something as we speak...Sanded it down even more, bondo, sanded up to 800 and tried rust-oleum chrome...lets see what happens.. - I will dry over night and wet sand in the morning...
1617158
Pretty satisfied so far...I am letting it dry until tomorrow and then wet sand and polish with buffing wheel...I will keep you posted..
1617206
1617207
this is the stuff i used...pretty cool finish
