Have about 500 miles since total rebuild so the flakey oil pressure readings had to be investigated.
The 1600 block has an oil port at the rear under the carbs that is perfect for a mechanical oil gauge. The mech gauge showed 65 cold idle and 20 hot idle, 57 hot at 2k. The Veglia sender would jump to 100 at times, just bogus.
Got this one from CA but it just reads 0 all the time, looks different and has different Ohms while at the bench, 5 vs 80 on the oe. They're sending a replacement so we'll see.
I think this is not for Veglia panel gauge.
