James,I recently removed my Veglia fuel sender unit on my 70 GTV only to discover that the mesh sock has partially dissolved. Is this mesh replaceable? Does anyone have one for sale? Thanks for your help. James
well, this screen seems and actually is from metal, I guess it is from bronze or something like thatModern fuels have been blamed for damaging/disolving fibreglass & carbon fibre tanks on motorbikes (it attacks the resins bonding them). I wonder if this is the same/similar problem.
The metal filter was probably original. After 40 years, the thing just fell apart, much like we humans begin to do after years of long use.Modern fuels have been blamed for damaging/disolving fibreglass & carbon fibre tanks on motorbikes (it attacks the resins bonding them). I wonder if this is the same/similar problem.
Excellent advice, Gary. I will be draining the tank.The metal filter was probably original. After 40 years, the thing just fell apart, much like we humans begin to do after years of long use.
I know of several Alfas and a Lotus from the same age range that all have experienced this problem. The metal pieces fall into the tank and can cause fuel starvation; they slosh around and end up clogging the fuel line.
Don't know about other Alfas, but my '67 has a drain plug on the bottom of the fuel tank. When the screen falls apart, it's a good time to flush the tank.
& when you do, look inside....................Excellent advice, Gary. I will be draining the tank.
Jamie, what is that third wire running over the back of the tank. Is that to ground the sender? Have you used a Veglia unit. I read in thread that the Veglia units work backwards. Is this true?& when you do, look inside....................
mine looked like this;
so this lot got fitted;
