In the forum for my Triumph motorcycle, there are posts about different motorcycles that use interchangeable valve shims. are there any other engines that use the shims for a 2 liter Alfa? I am going to be rebuilding my 74 engine soon, and would like to have a possibly local source for shims. the local source ( European Car Co.) closed down.
cliff
Hi Cliff, You can buy individual size shims from IAP. That's what I did when I rebuilt my 2.0L engine.
First measure the valve clearance on your new head and see whats size shims you need, then order them individually. The down side is the shims that they have they were not 100% exact size.
For example if you order 00.80 inch its either 00.79 or 00.81.
What I did I filed them down and brought them to the correct size.
Its very easy procedure and you save lots of money.
In most cases you can Always re-use at least few of your existing shims.
Giorgio
