1 - 5 of 5 Posts
Hi All
I have just replaced the brake m/c, Booster, flex lines, and rebuilt calipers on my 90 spider quad. All went well until I bled the last caliper and the pedal did not return fully. I couldn't move it back with my hand. this morning the pedal is back and is firm.
while bleeding there was a sound coming from the booster that reminded me of a whoopee cushion.
Looking through the workshop manual it looks like I should check the "no return valve". I thought the plastic fitting on the booster checked the vacuum but inspecting the old booster it looks like it is just a fitting for the vacuum line. Can anyone tell me where the "No return valve" is located so I can check and see if that is the problem.
Anyone have any ideas what I should check? They seem OK today but being that it's the brakes I would like to be thorough!
At least on L Jet and earlier cars, there is a one-way valve where the vacuum line comes off the intake manifold. I can't say specifically on a Motronic car. Can you post a pic of the vacuum hose take-off at the intake?
Follow the hose from the booster to the intake. Were the hose is connected is the valve.
The valve is basically only there to hold vacuum in the booster so you still get brake boost if the engine dies. If it fails I don't think it'll cause the issue you're describing.
Thanks everyone for the help! It looks like it is part of the intake manifold. I checked the valve and checked it all is well. I'm not sure what the sound was but the booster is working and brakes are solid. Now all I need is nice weather!
Andrew and Tom I hope you made out OK with all that rain you've had!
John
1 - 5 of 5 Posts
