My Engine is burning oil, and I’m so frustrated, I think I have had a lot done to prevent and stop it from using oil like a diesel. Let me tell you about my journey so you have the full picture of what has been done.
First off, let me say that I’m not an expert on Engine’s, so that’s why I have had a good friend and very skilled alfa mechanics with a background as an engineer to do all the work.
Secondly, I only use my car for trackdays, its not a daily driver, but I drive it back and forth to the tracks I love to ride. Mainly the Nürburgring.
Step 1. Engine was burning oil, and we suspected valve guides to be the problem. Changed the valve guides, had 1 mm shaven off the head for higher compression, a lot of other components where changed in the head to make sure everything was ok. Modified cam-wheels, so they where adjustable, to make up for the 1mm. had a Dastek Unichip mounted and the car was put on a dyno and adjusted
Everything was working well for at least for 2-3 month, and the engine was burning oil again
. Our theory was that the higher compression accelerated/exposed wear in the cylinders.
Step 2: Well the engine had driven 200k km, so it was probably time anyway. Everything went apart, I had 164s pistons 1:10, new liners, new rings. All went back on, the car was put on a dyno and adjusted. It went up to 222hp on the scale. It’s probably less in real wheel horses, but the point is that it went up from 190 from the first time on dyno, when the Unichip was mounted.
Now the engine was running smoothly, but when the car was on the track driving had, it gave huge oil clouds accelerating out of corners
. The theory was the compression was now at a level, where and oil catch tank was needed.
Step 3: An oil catch tank was mounted, it helped somewhat but not completely, and I had an extra outlet made in the left side of the engine. That didn’t change anything. After a good weekend on the Ring and lots of oilclouds, the engine was also smoking on the motorway returning home. Now the theory was that the rings couldn’t take the high compression
Step 4: The engine was split apart once again, a specialist took a look at the whole engine, and supported the theory. So new liners and new gapless rings from Total Seals was put in. Just to make sure the head was compression tested to reveal if there was leakage, but no. Everything was put back together, Mineral Oil was put in according to Total Seals instruction. Compression test was fantastic as always, but the engine smoked a lot. The theory now was that liners, and rings should settle. The engine felt good and strong.
Burn in period was done, the engine smoked less. But it does burn a LOT of oil. On the motorway to Nürburg (app 900km) the engine was using 3,5 liter, and I was driving with a relaxed right foot!
After a weekend on the ring and 2,5 liter more oil, I discovered some kind of pattern. When hot it smoke more than cold, when idling for minutes and hitting the gas hard it gives a nice smelly cloud. When starting the engine these clouds seems more often to appear when the engine is warm rather than cold.
Just some extra fact:
I normally use synthetic racing oil 10w-60
I got Greg Gordon stage 2 injectors installed.
It’s a Motronic engine with the S cams in.
What am I missing here? Are compression to high? Is my head ready for attention? would a oil cooler be the next step. Should I just settle and call it a diesel?
Here's the troublemaker:
