The plastic one are available on eBay sometimes quite inexpensively. I bought two.
The spline corresponds to a .875" x 19 unit.
If you get a plastic one you have to warm up the plastic pull ring on top and form it into a narrower oval so it can fit inside the throw out bearing.
Option two is to hack up an input shaft to a buggered transaxle. RJ might have one.
Option three is to mount pressure plate very loosely on flywheel and insert clutch cover onto transaxle that way. Then use the access hole on top of transaxle to tighten up pressure plate bolts.
Greg
