Hello all,
I disassembled my engine few days ago and discovered a damaged thrust bearing. I was told that the clutch thrust was responsible of this.
My concern is that not only the bearing was damaged but the suface on the crankshaft as well :(
My idea is to remachine the crank but i need to provide a new bearing (half moon) with a different size of course to compensate the gap after machining.
First problem is that the oversized bearing seems not to exist, only standard one. So i might have to do one in brass or similar auto lub. material.
Second problem, what is the tolerance gap between the bearing and the crank surface ???? :confused:
I searched everywhere on the web and couldn't find anything about this.
If one of you could have an idea it would be greatly appreciated !
Cheers
Fred
Hello all,
What is the tolerance gap between the bearing and the crank surface ???? :confused:
Cheers
Fred
Here is data from 24v engine specs.
Raahhh ! Steve you're THE data bank of this forum !
Thank you very much. ;)
Checked Spider, GTV6/Milano data and all shims seem to be same thickness and same crank end float spec.
