I know that Alfa Romeo 2L engines are supposed to leak a tiny bit. I like to drive my 1989 Spider QV in a spirited fashion, which the engine needs. I have noticed that after the engine warms up, I get the smell of burned oil into the cabin. Looking at the first suspect, the valve cover gasket, it is not the culprit. What I did see was some oil build-up on and below the variable valve timing device, which is the only leak coming out of the head.
The VVT works through the diversion of high pressure oil once the engine gets beyond idle. The VVT solenoid presses the plunger and allows the oil to flow and change the timing of the intake camshaft. There has to be some sort of gasket around the plunger to keep the oil inside the head. Can anyone verify this? I have looked at Centerline, Classic Alfa, etc. and did not find a plunger seal. Also, my Alfa Spider workshop manual did not say anything about a seal. If I can stop the leaking at the VVT, I will have one of the rare Alfas that does not leak a drop of oil.
Best Regards
Best Regards
