i am amost done with my ITB mod.:D i am using a throttle pos. sensorof a saturn,( it on / off type..:confused:( i hope, going to g.m. to get a wiring dia. for a saturn) there system is simpler than a bosch system..:)..no air idle motor , just a map sensor, air temp. and a mass flow meter.. nice and clean..:cool:..i am keeping my bosch lh system on stand by, untill i get more information on gm fuel injection..from what i can gather bosch is batch fire.. g.m??? see you all soon.;):)
1966-2013
I 'think' they are batch fire, but I'll have to look through this book I happen to have first to confirm.
Query:
Are you using the Bosch injectors? There may or may not be an impendance issue, (Bosch are low impendance. GM is???), and there's the whole flow rate thing to consider if you do swap to the GM stuff. (as in would the swapped in injectors be able to operate without going lean on you?)
Also, what year Saturn are you stripping the parts off? I know the one out in my garage has a form of an idle air motor. (a solinoid actually, but the principle and function is the same)
GM generally used the delco 808 ecu which I believe is batch.
You'll have to retune it and there are various aftermarket interfaces for doing that like this one. Page Title
Personally I'd use a megasquirt or something similar.
