1 - 2 of 2 Posts
As many of you know, I am clearing out 40 years of ALFA parts. This posting includes two lots.
1. Set of 4 pistons and con rods. The pistons are 83mm in outside diameter, with casting marks AE 2873 on inside. Three of these have 22 mm OD wrist pins. $100 + shipping (figure 12 lbs from US Zip 2003)
2. Set of 3 pistons and con rods. The pistons are 78 mm in outside diameter, with casting marks AE 2927 on inside; include 3 wrist pins. $75 + shipping (figure 9 lbs from US zip 20003)
Will accept any reasonable offer on either or both lots.
Notes:
The con rods are all the same; have an "alpha in circle" casting mark; are about 148 mm between pivot centers and 200 +/- mm overall length; bearing/wear surfaces are 53 mm ID on the lower end (most do not have a bearing in place) and 22 mm ID on top; include nuts and bolts but most do not have washers.
Might fit in USPS Medium flat rate box shipping at $12.65 in US
David
Discussion Starter #2
Priced reduced. Was asking $25 per piston/con rod. Will take $15 per + shipping.
Make me an offer for both lots.
1 - 2 of 2 Posts
