Parts for sale from the restoration of my 1969 Boat Tail 1750. Parts will fit other models and years. – Will sell the lot at a greater discount:
- special Alfa wrench for the metal injector fuel lines at the pump
- special wrench for the distributor bolt
- two fuel injection pump cores
- used but very good shape starter motor - $259.00 if new
- used plastic panels by each foot wells)
- two sets of used Lodge spark plugs – no longer available – just need to be cleaned for the car shows
- used 1750 injection air filter caster - it has the 1750 –plate on it with the air equalizers
- used slave clutch cylinder
- Sump Guard
- two used boosters brake – use for parts
- two used front brake calibers – need to be rebuilt
- timing chain links
- a few used valve shims
- used windshield cleaner floor mounted pump
- used floor mounted, cylinder petal parts and linkages
- used emergency brake handles and mechanism
- two used gauges and dash board rings – temperature and fuel
- used window crank handle – missing center cap
- two used petal pad for brake / clutch
- used water pump- rebuildable ?
I'm interested in the two wrenches at the top of your list. How much? Sent a PM as well.
I need e-brake mechanism at brake on end of cable and a spring lock pin for e-brake itself to lock on to hub. Any help???? Rear passengers side on 71 spider
