1 - 2 of 2 Posts
I was searching for a post I know I found awhile back on all the proper fasteners for the upper and lower oil pans on my 2L spider engine. When I reassembled everything, I realized someone had been in there before and the fasteners seemed to be all over the place.
I am experiencing some leakage from both upper and lower joints and want to correct this with complete proper bolt set and a few helicoils where stripping has occurrred.
Can anyone provide the link or the information.
Thanks in advance
On a 2000 they are 7mm bolts (11mm heads). There are several lengths needed for the different distances. I think any decent 7mm bolt would work; you don't need to get Alfa specific bolts or anything. I'm not sure there's a kit; just measure the distances needed and buy bolts slightly longer. They don't need to be killer tight.
1 - 2 of 2 Posts
