1 - 20 of 34 Posts
Selling a trove of NOS parts for Spiders (mostly for S3 but some fit S2-S4), unless otherwise stated: badges, emblems, electrics, suspension & engine parts and many more parts. See the folder in my google drive:
Here are the prices (all not including shipping):
-NOS Alfa badge 75mm $28
-New Alfa enamel badge 55mm (2 available) $25
-Used Alfa badge for steering wheel hub $8
-NOS Pininfarina badge $30
-NOS Alfa door handle covering S3-S4 (set of 2) $20
-NOS Bosch Thermo time switch $200
-Used Thermo time switch (tested good - 0 ohms cold and 140 ohms hot) $80
-NOS Spica/Bosch intake hoses for manifold (set of 4) $12
-NOS Bosch distributor cap $20
-New Bosch knockoff replacement distributor cap $12
-New Bosch knockoff distributor rotor $10
-New Magnacore KV85 Competition Red ignition wires with both long and short coil wires $85
-Used checked good Behr radiator fan switch $10
-Used good intake manifold for Bosch, with 2 temp sensors $55
-NOS copper exhaust manifold-to-head gaskets $10
-New copper exh manifold nuts (12mm wrench, Qty. 17) $20
-New brass exh manifold nuts (13mm wrench, Qty. 8) $10
-New tailpipe sealing ring $2
-New tailpipe hanger for Alfetta $2
-NOS Alfa rear swaybar to body bushings (pair) $2
-NOS Alfa swaybar end link bushings (pair) $10
-New poly sway bar end link bushings (qty 4) $20
-New poly shock bushings (Qty 4) $10
-New cam sprocket locking bolt and locknut (qty 2) $4
-New Cam sprocket locking tab washers (qty 3) $3
-New timing chain master links (4 available) $5 ea.
-New bronze valve guides (set of 8) $25
-New convertible top cables (set of 2) $18
-New clutch hose $10
-New in-tank fuel filter/screen for Bosch $6
-New Lemforder inner tie rod ends (set of L & R) $60
-Used steering wheel nut and tab washer $10
-New Engine gasket set (missing head gasket, cam cover gasket has break but is repairable) $15
-New Mille Miglia center caps, 48mm, with attachment bar $90
-Used Mille Miglia wheels 5-3/4 x 14 with 4x108 bolt pattern, set of 4. All have “ALFA” embossed on face (offers).
-Used OZ Route wheels 7x15 with 5x98 bolt pattern, set of 5. For GTV6/Milano. One of them is slightly bent but is repairable $125 plus shipping.
Hi Steve,
The Mille Miglias are straight, no cracks, no curb rash, a few paint chips down to the metal. They present well as is or are a good candidate for refinishing. These are $1200 in restored condition, just to offer an endpoint. Thanks for your interest.
Best,
Jim
Don't have permission the view pictures.
Thank you for the heads-up, Jim! I am very sorry the link doesn’t work. Let me try to put them somewhere else. Or just start uploading here.
Are the sway bar link bushings front or rear?
Discussion Starter #18
I have 2 OEM end link bushes for the front (30mm OD) and one OEM end link bush for the rear (25mm). The red and yellow poly bushings are for the rear end links. Hope that helps.
Discussion Starter #19
Adding S3 spider ECU’s, removed from a fully functional excellent performing low mileage ‘84 Spider:
Jetronic FI for ‘82-‘85: $190
Motronic Ignition for ‘82-‘89: $190
If you buy both, price is $350
All prices plus shipping.
1 - 20 of 34 Posts
