Actually, I do have that gizmo on the RF fender! The car is an 81 Spider that had the dual-points Marelli, but the engine in question is from a 75 Spider (?) and will be getting a BT 123 Ignition.Jim's post #8 here pretty much describes what that vacuum port did
that line would have a "T" in it and in fact go off to two places:
Question: Where Does This Hose Go?
this plastic thing is the dual points gizmo he speaks of (iirc was fitted to 78 on, so not sure about it on a 75)
Have you a dual points Marelli dizzy?
The 80/81 originally had and awful marelli plex electronic distributor in them.Actually, I do have that gizmo on the RF fender! The car is an 81 Spider that had the dual-points Marelli, but the engine in question is from a 75 Spider (?) and will be getting a BT 123 Ignition.
Actually, you’re absolutely right — it has the marelli-plex, and it was awful. 😁The 80/81 originally had and awful marelli plex electronic distributor in them.
