1 - 20 of 72 Posts
Greetings,
I have been giving a bit of thought to building a replica of some description and the ultimate for me would be either a 33 Daytona or Stradale coupe - but to achieve that to a very high standard is going to be extremely costly. The chances of actually locating a Montreal engine are pretty slim (let alone a genuine flat plane crank Autodelta V8) and a Colotti gearbox. Googling around I found references to 2 or 3 outfits that are building replicas no doubt with varying degrees of quality.
I came to the conclusion that a TZ2 coupe would actually be a bit (at least) easier to recreate. My idea here is to build a close interpretation with minor modern comforts using mostly fairly easy to get parts. Another reason is the similarity of the layout compared to clubmans/locost kit cars that are very popular. Apparently accurate CAD designs of the TZ2 are publicly available, although I'm yet to view a copy - if anyone has DXF files, please get in touch. NOTAR Cars claim to be making replicas to a high standard although their website has not been updated since 2005. Does anyone know if they are still in operation?
My aim is not to build an exact copy - but a replica that can be used and registered on the road and possible used for occasional track sessions.
Here is a summary of my ideas for a TZ2 replica:
- tubular space frame based 99% on the original car but with increased tubing wall thickness to increase strength of chassis
- utilise Alfa 75 twin spark engine, 105 series gearbox, steering column and possibly 105 series live axle - I would like to consider an independent set up with inboard brakes however I can't think of any readily available options for this - perhaps Fiat 130/131?
- the twin spark engine would be standard to get the car through inspection/registration
- utilise a modern AC kit as the car would no doubt be a bit of a greenhouse and I live in a hot climate (South Australia)
- fibre glass body - my Alfa history book collection indicates that the first TZ2 was constructed in alloy and subsequent cars were made in fibre glass using a moulds from the original prototype, so a fibre glass body is not technically "inaccurate". That said, I'm not put off on the idea of creating a hand formed aluminium body.
If someone already has body moulds and is willing to sell a complete shell then at least some of the hard work has been done. Other concerns include:
- windscreen / rear screen - are recreations available?
- wheels? Does anyone make replicas of the original wheels? I believe at least one TZ2 had larger wheel arches and was fitted with Tipo 33 type wheels too.
- suspension - this will probably be custom made to suit the chassis. Spring rates and shock absorbers will need to be carefully considered.
- internal and external trim
- instruments, lighting - lenses and fittings for various Italian brands seem to be still available if one searches hard enough (Carello, Siem, Jaeger etc)
- seats - I have found a classic car seat manufacture that builds something similar to what I've seen in the TZ2
The more I look into it the more complex the project seems, however I have a couple of aces up my sleeve - I'm technically skilled and already have multiple cars under restoration and can use CAD applications with FEA to analyse stresses and loads on the mechanical components. I also have access to a professional car builder's shop with over 30 years experience with the engineering and compliance of custom vehicles (mostly clubmans).
Comments/criticism welcome :)
TZ replica
Don Ereminas in Torrington, CT had a TZ replica he was developing. I heard he closed the parts business but was continuing with the TZ work, but that was several years ago or more.
I found a photo here, sixth photo in the top thumbnails:
PhotosDay07
Hi mate, an interesting set of ideas and not with out merit, albeit it would be a difficult journey.
However, just to help you along a little bit, over on the Aus Alfa Romeo Owners Forum, there is actually today a story about someone who is building up (I think) from scratch a tipo 33 stradale. No idea about the mechanicals but the pics show the bodywork to be very well executed.
I am pretty sure also that the are a number of replica TZ2s out there, but how exactly made, the specs I don't know. I do recall seeing some threads either here on the BB or on the Aus forum re this. I have a feeling (could well be wrong), that there is one in Victoria.
Re engine choice, I would have thought best options would either be a twinnie or a 105 engine. The Fiat 130 is a V6 and I would suspect would be far too heavy. It is also very wide and a large motor. The 131 (early ones were 1600 pushrod, so nothing very exciting, while later versions used the classic Lambredi twin cam that was fitted to the 124 sport, spider, 124 Special T, 125, 132, Argenta. And later was slightly modified for inclusion in the Lancia Betas etc. An excellent motor but has no Alfa heritage.
I think in terms of engineering, the design of the chassis would be critical, that is both getting the correct dimensions, let alone geometry right. As far as the bodyshell goes, I would imagine, that with access to CAD etc that would help, but better still is being able to benchmak against a real car, for all the correct details. You might like to get in touch with someone like Phil Nash in the Vic AROCA, as he might be able to help you re your ideas. Afterall I think he has a TZ2 ?????
Good luck, anything is possible if you are keen to give it a go. There is a guy down here in Hobart who over the past year or two has built from scratch a Mercedes 1930s period racing car (can't recall the specific model) but the engineering, the bodywork etc is truely awesome. It runs a Jag V12 motor.
Don is still in business, and his ad in the current Alfa Owner states: "Home of the TZ Replica". Some nice images here: Alfa-Romeo Parts
Don Ereminas in Torrington, CT had a TZ replica he was developing. I heard he closed the parts business but was continuing with the TZ work, but that was several years ago or more...
Hi all,
Firstly thanks for all the public and private feedback I've received so far - it seems recreating a TZ2 (and the TZ1) is something many have considered, and a few have taken on this daunting task with varying degrees of success.
With reference to ideas for utilising Fiat components above, I was actually thinking along the lines of just the rear differential and suspension components, not the engine, transmission etc from the Fiat 131 or 130 etc. I would like to utilise as many parts as possible. In one instance, someone converted a standard 105 series rear axle to an independent set up. Another option would be to utilise the rear differential and suspension set up of the Alfa 6 as it did not have a transaxle like the Alfetta sedans and GTVs.
I have set myself some realistic targets - my "recreation" will not be an exact replica with period correct Autodelta components - a period engine, gearbox, etc is seriously big money. But I do want to get the body shape and the chassis as close to the original as possible including the independent rear suspension with inboard brakes. I have not made a decision as to go with fibre glass or hand beat alloy - both options will be a challenge!
The biggest problem I have is actually getting access to a real car to take measurements from. CAD drawings appear to be available - but are the authors willing to share?
Cheers.
Benjamin
Hi!
For rear differential you can use the Alfa Sei parts: it's a normal diff with inboard brakes and can be modified to wfully ork with independent suspension.
Regards, Alvaro.
TZ2 Replica
Hi all! My name is Pierre KREBS , I built a TZ2 replica with transaxle gtv6 donor parts , it takes more than 10 years to have the car ready but not finished tha was in 2004, it's a long way to fix everything and to develop and fix handling , power .................. This car is not street legal only for track use , so it was a very long and hard time to built this car and it was very expensive !!!!!!!!!
Hi Pierre
That is some awesome looking machine!
I have absolutely no intention of taking on a similar endeavor but I would be fascinated to know more with piccies please....
Congrats Richard
hello,
i am currently tackling a 33 stradale replicar- i don't have much yet besides the monty engine and a busted-up transaxle but have full prints and engineering know-how. i would love to find someone to build an alloy body on a buck i can provide but if it proves to be too costly i may opt for carbon/glass shell of my own construction. these are not easy undertakings but stick with it mate, in the end it will be worth it!
Holy mackeral! That thing is stunning! You aren't just going to tease us with a single picture, are you? Where can we see more?
bs
chiuso per ferie
A company builds them. Contact is Christian Giordanengo ... and he is a member of FerrariChat. Just add $'s ...
More help...also to myself
Hi busweiser
I am on the same idea with replica, but i need somebody to do nealy all the work for my. I was therefor considering to get the complete chassis from a donor car that gives close to the same dimensions, havent decided yet.
But have you ckecked out these guys ? Welcome to topgeartvseries.com | topgeartvshow.com Cars | topgeartvseries.com Catalog | topgeartvshow.com Engine
And does anybody know about them ?
Keep me updated on your project, really want to join in and work a similar car
Many greetings,
Niklas Walentin
Denmark
A few thoughts
There must be a problem building TZ2 replicas for a reasonable price because there are lots of good replicas of more complex cars around.
Its a little hard to see why.
Body is originally fibreglass so easy to copy -- once you have made one producing more should be no problem.
Tubular frame is also original so once you have built a jig for that also no problem.
105 mechanical parts are not in short supply, the replica won't be original but it will be Alfa Romeo and totally period.
Correct wheels etc are available.
TZ2 was/is a race car so dash/trim spec is not really that important.
I would have thought there would be a market for race only TZ2's at a reasonable price but maybe not.
here is one for sale in Germany
Race car project For Sale (1964) on Car And Classic UK [C219319]
Someone must have made moulds etc.
Price may be justified by twin plug engine etc but still seems very high for a project.
Discussion Starter #20
The only production car that comes to my mind with a suitable rear end for a TZ2 replica is the Alfa 6 - rear differential with independent drive shafts and inboard brakes. As a bonus it has a nice cast diff body and it is actually made by Alfa (or for?). I assume the Alfa 6 diff is a ZF?
I'm now starting to think along the lines of building an "approximation" to the TZ2 as I do not have access to a real car. I'm not sure how accurate can get from simply trying to measure off pictures. Building a car from scratch is never going to be easy and my concern is that it will always feel homemade...
Thoughts?
Benjamin
1 - 20 of 72 Posts
