just looking for some infomation on turboing a twinspark from a 75 using the standard motornic injection sysetem,
i know greg gordon uses the bosch l-jet system with a micro fueler? on the v6's and has very good results.
can a similar thing be done with the motronic on a twinspark?
i know this system would be less than ideal and for optimum results a complete aftermarket system should be used, but for a low boost application it will be good enough to get me started.
the pic below appears to be using the standard motornic, so it must be able to be done succesfully?
cheers, Brad
Theoretically it could be done but you have to find someone who can actually adjust both the fuel and ignition maps in the memory chip.
Where those maps are actually located within the pages of binary code (if you've ever seen the raw computer code from an ECU memory chip, it makes zero sense without software to organize it) is not largely known.
Save yourself the grief and go a decent stand alone system. By the time you've made the factory system work with your Alfetta chassis (probably not that hard) and you've massively altered the breathing characteristics of the engine with a turbo, compromised systems like either an archaic factory ECU band aided with a micriofueler (you haven't even addressed the new requirements for ignition timing) or if you could get it done, a reprogrammed archaic factory ECU, just aren't worth it.
The new Haltech Sprint 500, EMS 4424 and Adaptronic E420c would be great choices. Then there is the recently released Megasquirt V3 which is very well priced and capable, too. All of these can be should be easily configurable to work with the Bosch 60-2 crank angle sensor.
Do the job right and get drivability, reliability and best performance. It won't cost much more but the end results will more than outweigh the extra expenses.
Just to clarify, a "microfueler" is an additional injector controller. Callaway used one to control two additional injectors that were triggered to spray under boost. It had no effect on the stock injection system. I never used this system.
My method was to use larger injectors combined with my "black box", various check valves etc. The black box is a signal interceptor that modifies the coolant temp sensor's signal when under boost. This worked very well.
You can do pretty much the same thing with Motronic, no it won't be as good as a modern system, but it will work.
Greg
