1 - 5 of 5 Posts
Hi All, I am in the process of converting my 105 and am looking for the fuel pump connector from the 75 loom.
I believe it to be a pink and white cable from the relay.
This conbloc in the wiring loom seems to be spare and was wondering if this may be it
Also what size inline fuse should I use.
Many thanks for any info.
https://plus.google.com/photos/107401812919009580720/albums/5534217498081073089/6100209622865855858?authkey=CLnIzN3jyp_ZvgE&pid=6100209622865855858&oid=107401812919009580720
https://plus.google.com/photos/107401812919009580720/albums/5534217498081073089/6100209600215218482?authkey=CLnIzN3jyp_ZvgE&pid=6100209600215218482&oid=107401812919009580720
Chris
yes i think thats the correct one from memory.
I cant remember what size fuse i used, but i can check if no-one comes up with the answer
Yes, that looks like the one. From memory it is the only pink and white cable in the engine bay. On the 75 it runs from the output of the fuel pump relay around the back of the engine to that plug which sits between the intake plenum and the firewall.
It then passes through the firewall and into the back of the fusebox corresponding with fuse 13 (although I can't remember the rating sorry). From there it runs direct to the fuel pump plug underneath the righthand rear seat.
1 - 5 of 5 Posts
