1 - 12 of 12 Posts
87 Spider. All turn signals light but don't flash. Anyone have a solution?
Flasher location?
Same problem today with my '74 Spider. All light, no flash. So I too am interested in location of flasher. (Suspect that it's under the dash, but where?)
Bob,
I'm loosing my mind, my problem is also with my 74, that part is behaving on my 87 Quad. 2 Alfa's, twice the challenges and fun!
Mike
87 looks like a relay and is located in the drop-down fusebox above the fuses. 74 is a four pronged box under the dash, originally attached to the steering column support by a machine screw through the center of the box. yours may vary
Thanks Rogerspeed. Bob, Rock auto lists the part for $2.45
The flasher for the 87 is indeed in the fusebox but it's location differs depending on the type of fusebox. For early fuseboxes with bullet fuses, the flasher is on the second row down, second from the left. For the later blade style fuseboxes, it's on the second row all the way to the right.
the rock auto thermo flashers are incorrect for both the 74 and 87; though it might be possible to jury-rig on a 74. The original flasher, for the USA from at least 71 on, were electronic.
Jim, I may have been mis-informed, wasn't the fusebox change to blade mid-86?
I don't recall if there was a chassis number listed with the change but the parts books (microfiche actually) show the change as having occurred in 1987.
Thanks guys, who sells the electronic flasher?
My other Alfa, the 87 has blade fuses.
I've requested my 74 be added to my signature, but no response. Can this be done with the"free" account?
I may have a good used flasher for the fusebox (87) The original type for the 74 is hard to find and may not be available new, you can substitute a VW or BMW four prong from that era which are still available (aftermarket and dealer), each prong (terminal) has a number (din code) just match the numbers. You can also use a generic American four prong electronic flasher, but you'll have to do some figuring as the identification system for the prongs is different. With either approach your signals will flash, but not always the indicator.
As to your signature, try clicking on 'user cp" then "edit signature"
PS - the 74 original type maybe repairable, do a search
Guys, thanks for all the info!
Another task to add to my ever growing list of Alfa to-do's. Meanwhile my left hand will provide manual flashing.
1 - 12 of 12 Posts
