My turn signal lever broke off while I was driving. I can still push the little nubby up and down and the signal works. Is there any way to fix it or do I need to replace the entire mechanism (which includes: high & low beam and wiper blade lever)?
Lotsa luck finding the part.
Hopefully you can reattach it with epoxy or Gorilla Glue, and be gentle with it...
Here is another thread that I found very helpful when I needed to take apart my headlight and turn signal switches to clean and get them operating again:
http://www.alfabb.com/bb/forums/spider-1966-up/429249-inside-combination-switch-exterior-light.html
Many thanks to Jay and Eric.
If you go the route of replacing the entire switch assembly, I would look on ebay. I found a couple of used ones there under $150 each. One worked perfectly (thin shaft type from an '82 or '83) and that one was about $140, while the other one (thick shaft type from a '90) turned out to only be useful for parts, but it was just $99.
