I have a problem with the turn signal indicator in the dash. I can make it flash, but the default condition is that the light stays on when not flashing, rather than off. I suspect that I may have done something wrong here.
I know about zero about electrical systems, but I'm having a good time learning
. I fixed the turn signal switch in the steering column; pretty simple switch unit and now the turn signals themselves work fine.
I have located the flasher unit in the fuse box and attached the positive lead on the indicator light to one side of the unit... grounded the neg lead and fulmineo! This gives the desired flash, but leaves the indicator light on when not flashing.
My patient is my 71 Spider in which the PO replaced the old fuse box with a generic modern fuse box. Although the basics work (headlights, brake lights, parking lights - now, wipers ) Iacquired the car (through a 3rd party) before he finished the, ahem, detail work. So, for example, the turn signal indicator unit between the tach and speedo pods was empty. I bought a light and started playing.
Since the fuse box is different and the wiring has all been replaced, there's no guarantee that the color coding on the wiring matches the wiring diagram.
I have located the turn signal fuse in the fuse box, and attached the pos lead there, but this only lights the indicator with no flashing action.
I am sure that this is pretty simple stuff, but I'm apparently too simple to figure it out.
Help please!
