Trying to track down a problem. Thought I'd ask before I go and start touching things with the ohm meter I shouldn't. Is it okay to check wire continuity between the CSI and TTS plugs? Leaving TTS connected, and testing W from CSI plug to ground (since W from the TTS is supposed to connect to the CSI directly). Only problem is to determine which connection is W on the CSI plug.
Also, tested cold (room temp about 68F) TTS is showing:
between G and ground 32.4
between W and ground 00.2
between G and W 32.4
CTS cold is showing 1.260
Since W is supposed to show if the switch is open or not, is this indicting the TTS may be bad?
Haven't had a chance to test with a warm engine yet.
