Not that I'm planning this anytime soon or at all. So mostly hypothetical at this point.
On the TS 75 engine, the exhaust distributor could be removed and replaced with a cam position sensor in order to drive coil packs, no? Is there a product that would mount there, or would that have to be a custom adaptation?
Obviously aftermarket ECU, of course.
I'm sure some have ditched the distributors for coil packs, but not sure where they took the cam signal.
And probably a strange question with the most likely comment to be "why would you do that?", but anyway - could the above be done for one set of plugs and the other set of plugs be left with one coil and the lower distributor?
