Before I continue, there are a myriad of posts for the same issue, and I’ve read most of them. Still stuck. I have an 88 Spider Quad. Car ran when parked a month ago, but now it will start very briefly and cut out after about a second or two. It then won’t even start up at all unless I let it sit for a while and the same sequence will happen: starts for second, but none after that. Here’s what has happened since it was last parked:
-I pulled the gearbox and did a full rebuild.
-I’m also prepping for a new interior so the cabin is pretty much gutted: no seats, seatbelts, center console, upper console, carpet, etc.
Here’s what I have tested/tried thus far:
Resistance checks on the following sensors:
-AAV: OK
-TPS: OK
-Altitude comp device: OK
-the two flywheel sensors on the bell housing: OK
VVT: OK
TTS: Not OK, tests as always “warm” so the CSI doesn’t fire. Shouldn’t matter, I don’t think.
CTS: OK
Fuel pump fuse: OK, but replaced anyway
All other fuses (ones in footwell, 8A in engine bay, 15A in engine bay): replaced all
Other checks/repairs:
-cleaned grounds in engine compartment
-cleaned ground on bell housing
-cleaned ground in rear parcel shelf
-cleaned ground under battery
-hooked up compression tester to CSI supply and saw 35psi
-can feel the main relay and drive relay kick on when key is turned, although the drive relay doesn’t every time. I imagine the only times it kicks on is when I stated earlier that it starts first try and then I have to wait a while to get it to go again.
Next steps until I hear from you guys:
-if I can get my girlfriend off her horse to help me, I want to put my hand on the fuel pump to see if it’s going while cranking.
-try swapping main relay just for kicks.
If you’ve made it this far in reading, I commend you. Thanks all!
try jumping the fuel relay (the big bosch one near the ecu) pin #30 to #87
that will (should) make the pumps run continuously and if so confirms the wiring to pumps is good as is the 'troublesome' 8A fuse holder .
(you changed the fuse, but if you still have the original bullet fuse holder they usually cause all the the problems...best just swop out for a blade fuse holder, or at least check it very carefully)
does it start and run when you jump the relay?
YES, YES IT DOES
Hooray then that relay is bad
Hard to find the big original Bosch relay and costly when you do find it!
KAE do a replacement which works but can leave the pumps running
that’s sad because the previous owner apparently replaced it less than a year ago. Maybe there’s an underlying issue... good thing I cleaned all the ground connections! Off to the salvage yard befoe they close, maybe I can find on an old BMW.
