Transportation of the un-wheeled.
1120 Views 9 Replies 6 Participants Last post by  Bobcatmo
How do you transport (or have shipped) an Alfa with no wheels?
It's a stripped body 600 miles from me.
Do companies like DAS do that? :confused:
1 - 10 of 10 Posts
Just guessing but I wonder if you could attach it to a heavy-duty pallet. Or maybe some sort of body dolly. Another dolly. This dolly probably wouldn't be what you need...
Depends how much she can dead-lift.
I just need to figure out how to get it from FL to NC.
IAP had those rollers you put under a wheeled vehicle to move it around your garage/shop. They might work on the unwheeled?
Alternately Assuming you have Front and rear hubs, if you bought 4 emergency spares from a Ford Focus ($15 each from the wreckers)....
Just a thought.
Elio
This is just a shell: No suspension, no nothing.
uship
Just listed it on uship, sort of a LendingTree.com for auto transport.
Very interesting. Do let us know how that works out. Also, the youtube videos are pretty good...
Funny stuff. :D
3
I built a simple dolly to move my Sprint GT body from my garage to the media blaster and then on to the bodyshop.
The dolly was quite easy to build - 4 heavy-duty casters, some 2X6's, and carriage bolts. The casters were positioned under the points where the body attached, so the wood wasn't carrying much weight. And, a stripped Alfa body doesn't weigh much.
This worked fine, transporting the car a few tens of miles on a dedicated flatbed hauler. Now, whether a common carrier would accept such a vehicle is another question. Often vehicle transporters will only accept running cars. Obviously one of those two level trailers that holds 8 or 10 cars couldn't accommodate a body supported on little casters with a 3' track width.
Note: If you do use a dolly, attach your tie-downs to the body, not to the dolly.
John.....if you haul it yourself.....stop by on your way through and you can pick apart mine...:D
1 - 10 of 10 Posts
