Senior TEXAS member
Just a thought or two...Has anyone heard of the possibility of swapping out the trans/rearend of a Spider and working in the Alfa transaxle setup? Seems like a great way to put some of that nose heavy weight into the rear and balancing out the distribution.
What are your thoughts?
Bill
Hmmm gotta do some powerful thinking on this one. That is an idea that sounds good but it will be a good idea only if it is possible without major surgery. The issue I think boils down to the transaxle requiring an independent rear setup. And a place to transfer the torque from the axle to the chassis. The torque question doesn''t seem too difficult, but fitting the independent axles, and springs will either be a zip its in or a noway. Have to put them both up in the air and do some measuring. Do you know if the track is even the same or close? I don't have access to a transaxle car now so can't go much further.
MrC
In the first place I don't think the transaxle would even fit. You'd have to basically rebuild the whole aft end of the car including underbody. I'd be impressed if you could do it, however.
Fuggetabouit.
Senior TEXAS member
Discussion Starter · #4 ·
The idea came from a very cheap gtv6 on ebay as a parts car.
I always liked the way my Rover 2000 tc handled with the inboard brakes on the independent Dedeon (sp) tube rear end. Very will balanced. I dont know if there is room but it might be fun to try to take a parted out Spider and modify with Alfas transaxle rear end. Keeps the ole brain bucket working.
Keep those thoughts coming..we might be on to something!
