1 - 10 of 10 Posts
Does anyone out there have a suggestion for a replacement to the tar like material that is used for sound deadening and heat insulation around the transmission tunnel and the floorboards? I have done some "modifications" and need to replace some of the old insulation that did not survive.
Any suggestions would be highly appreciated.
Thank you,
David
· Senior TEXAS member
AC duct wrap foam insulation.
1/4" sticky-back dense foam with aluminum coating on the outside. 12"X 25' $14.45/ roll at the Depot....
Works great as a sound deadener/heat insulator!!
Discussion Starter · #7 ·
Thanks so far.....
Hey thank you all for the good ideas. I'll be deciding what to do in the near future and if there is any interest on the BB I'll do up a photo-documented thread on my "modification."
David
· Premium Member
Hmmm... I just noticed the "soon to be a turbo" signature. What'd you do...put an automatic in there? If you did, I hope you didn't cut much of the tunnel away as it does help keep a spider from breaking in two!:p
Discussion Starter · #9 ·
Nahhhh noting as bulky as an automatic, besides a sports car with an automatic? Sounds like something a friend of mine would do. I stuffed a Ford Motorsport t-5 in there. As to the tunnel I am reinforcing it and will install a new piece of sheet metal to replace what I removed for additional clearance. It should be almost good as new. The Turbo... Still working on that and getting closer. Maybe..... by the beginning of summer.
David
Discussion Starter · #10 ·
Bill S. Looks nice by the way. Bet you can't wait to get it finished!
David
1 - 10 of 10 Posts
