1 - 19 of 19 Posts
Touching up your old wheels
When I purchased these wheels, they were scuffed up, curb rashed and dirty.
With a little dremel work, brake cleaner solvent and the right paint, you can make them look good again.
The paint is the same paint used on BMW motorcycle air heads. It's heat resistant and very durable. It dries a little bright at first but the color will settle in and look perfect after a week or so. About $30 a can.
I learned the card trick from an old body shop buddy. Takes all of one minute and better than taping....
I didn't do a total redo as I could have filled in, sanded and finished a few pitted spots but it's good enough for what has become my daily driver..
If you need any help, ask!
BEFORE (actually this was after the final clean up, ready to paint. I didn't take the real "before" pictures...)
AFTER
I'll ditto Eric on the playing cards idea. This is another project for my To Do List!
Thanks for sharing,
David
Looks good, ready to do the same on my 74. You're obviously good with a spray can, I'll be taking mine off the car so I can lay flat to avoid runs.
Believe it or not, it's harder to get a good spray when it's laying flat. The reason is due to the positioning of the rattle can.
Leave the wheel on the car and just do several "dusting" layers. In other words, keep the can at about 12 inches away and LIGHTLY "dust" the wheel with paint. Moving your can around in half moon motions, top first, bottom second.
Do this several times allowing appropriate drying time. If you lay it on too thick, you will get runs. Do not spray from too close ( < 9" ). If you do remove the wheel, keep it straight up.
God luck.
Nice job. What did you do to prevent paint getting on the rotor?
God luck.
Took your advise. Happy with the results. Thanks for the tip.
Why am I getting flashbacks from when I was a kid and clipping playing cards on my bike so they would hit the spokes? :thumbup:
Discussion Starter #12 (Edited)
Ha, ha, As you can see from the picture,...nothing. I should have stuffed some newspaper back there. It would have saved me the 3 minutes it took to remove the overspray with lacquer thinner...
It wasn't that difficult because the rotor was dirty. The road grime helped keep the overspray from actually adhering to the rotor.
Discussion Starter #14
Looks Good! Wish I would have kept the set of phone dials I had bought..
One final thing. Resist the temptation to shoot clear coat over it..you will regret it.
One final thing. Resist the temptation to shoot clear coat over it..you will regret it.[/QUOTE]
Too late on that. Had good results with clear. Used VHT high temp clear wheel paint.
Too late on that. Had good results with clear. Used VHT high temp clear wheel paint.[/QUOTE]
I used VHT high temp clear caliper paint for the spark plug cover on my Fiat but it ended up yellowing after a few weeks. Will strip it off and just keep it bare.
Phone dials are unbelievely heavy for an alloy wheel. Made my 88 quad ride like a cattle waggon over rough road surfaces. Replacing them with a set of Superlites was the best investment I made on the quad.
Robert
1 - 19 of 19 Posts
