How do you all go about torquing the front hub nut?
Manual says torque first to 14 ft-lbs while spinning hub. When I approach 14 ft-lbs the hub starts binding a bit... doesn't spin as freely. Is this right?
next step is to untorque the nut and then retorque to ~7ft-lbs. Well my clicker type wrench starts at 10 ft-lbs... do you all use a beam type torque wrench for this or just wing it?
