I dropped off a newly acquired set of never-mounted 25 year-old Cromodora Daytona wheels to get tires mounted and got a call back from the shop saying they ran into a problem. They found that the valve stem hole is smaller than any stems they have in stock. They didn't tell me what the hole diameter is. I've never had this issue with UK or European wheels before. While the shop is researching alternatives, I thought this group might be able to shed some light on the situation.
The seller told me the wheels had been purchased from Centerline about 25 years ago. They appear to have been from a production run that Frank Hanel in Germany arranged. A CD6xx model number and "Made in Italy" are stamped on the back of the hub.
Any ideas or suggestions? Is it possible they require bolt-on stems or motorcycle-spec stems?
As an aside, I also found that the hub center is 54mm in diameter, and no one carries Alfa or Cromodora center caps for this I.D. I found a guy in Portugal who makes plastic caps and Alfa logo badges to match that size, so that problem is resolved.
