1 - 5 of 5 Posts
I have a 79 and need to "re-tire" it. Since 165's ,which the oem tires were, are difficult or impossible to find, what sizes are folks using these days which fit well on the 5 1/2 rims and allow full clearance to the fenders and frame?
TIA
Rusty
185/70/14 fit the rims, work well, and have a similar rolling circumference to the full profile 165s, so gearing is not impacted.
The steering is slightly heavier, dry road grip higher though.
165s are easy to get (though usually need to be ordered) in the UK, maybe not so easy elsewhere. 185/70s are common, and inexpensive.
Jonathan
Jonathan
Thank you Jonathan..
Rusty
Certified Oldschooler
Spider Tires
I've used in the distant past (on a '69) without any clearance problems, Michelin XWX 195-VR 70-14's. These are aobut the maximum. These with a Shankle street suspension kit. I recently put on Yoki AVS ES-100's in 185-HR-60 and they are too small (and rough). These with Cromadora Daytona 6x14 (22mm offset) rims. Have not tried either with stock 5 1/2" rims. Bruce
1 - 5 of 5 Posts
