Tire Recommendation for a 1994 Series 4 Spider Veloce
3637 Views 42 Replies 19 Participants Last post by  CADCHUCK429
Looking to replace all 4 Tires for my 1994 Spider Veloce. I live in Southern Florida where the temperatures on average is 80 degrees. Has the stock 15" Phone Dial wheels which I believe carry a tire size of 195/60 R15 which I want to stay with. BI mainly take the Spider out on weekends with both highway and local driving accept if it rains. Previous owner tires finally gave out with a right rear blow out on the highway doing about 80 MPH. Tire was shredded to pieces scary moment. Any recommendations would be greatly appreciated.
Thanks In Advance,
Chuck
1 - 20 of 43 Posts
1690418
Did it look like this? This was my right rear after a blowout at 90 ish on the drive back to Minneapolis after buying it in Colorado Springs
I replaced all four with Toyo Proxes 205/55R15 88V on a 15” GTV replica rims.
1991 Spider Veloce in BRG
I run Pirelli P4 All Season 195/60R15 tires on my phone dials. Very happy with them.
Reactions: 1
Thanks In Advance,
Chuck
michelin, Bridgestone, Yokohama, pirelli are what I use. Most important is tire rating. V rating should suffice for spider speeds. Also may want to consider a M&S rating. Finally check the letter ratings on the tire for treadwear, traction, and temperature. Highest ratings are AAA in each category. Let us know what you choose.
V rated on a spider is a bit over the top - had them on the Montreal but that was different.
H rating (OEM rating for our spiders) is good to 130 mph.....your spider will explode at that speed before the tire will;)
I run Vredestein Quatrac 5 in 195/60-15H , which is an M&S all season tyre....they are v.good in the wet (snow too) and are quiet tyres.
but if you live in a mainly dry climate then obviously you don't need an all season.
Reactions: 1
V rated tire has more robust construction and will provide better handling. Not about top speed rating.
Yes! That's exactly how my tire looked.
Thanks for all the recommendations. Anyone out there running there Series 4 Spider on Summer Only tires instead of All Season?
Thanks-Chuck
Thanks-Chuck
@FrozenRomeo has summer only but I forget the brand and model. They’re really pretty tires 👀
" Highest ratings are AAA in each category "
I don't think it works this way. It's more like lightweight, stiffness, price - pick two!
Thanks-Chuck
Sure, I used to do that when there were more available in the stock size. You're in Florida, summer tires would be fine for you year round.
That said there's only one summer tire available in 195/60R15 that I can find right now, the Vredestein Sprint+. It's V-rated but I have no idea how good it is.
I had the P4's before - great tire.
Went with something different this time with Nokian's.
I personally can't tell the difference between them.
Reactions: 1
I'm looking at the Yokohama AVID Ascend GT Seems like it works good in dry or wet roads not so good in the snow (snow not an issue) Almost like a summer only tire.I can Pick up 4 under $300.00 via Amazon with free shipping. Any thoughts, opinion, etc.
Chuck
@CADCHUCK429, I just went through this two weeks ago. Check out my thread.
I wanted a summer performance tire more so than an all season M&S rated choice. I purchased the Vredestein Sprint + which happened to be the most expensive tire offered by Tire Rack. I only have a couple of days and less than 100 miles on them, but I have no complaints what so ever. The are sooo much better than the 10 year old Good Year Eagle GTs that were replaced.
Reactions: 1
I did see those tires but it seem it was gearing to the older classics from the 60 and 70's for appearance.
Dude, your car is an older classic.
Is a 1994 consider a classic? How do they look on your 88 Graduate. I know you only have 100 miles on them but did you notice any differences on the positive side such as road noise going over bumps etc.
Your 94 is basically the same car as the 69 Spider with 250 more cc, Bosch injection, and different bumpers and interior. As I said, they are so much better than the old Good Years that I had. Quieter, smoother, more grip. No downsides, that I have noticed. Most any NEW tire will feel better than your old tires. If you can afford the price, get the V Sprint +. If not, look at the KUM HOs; just don't tell your wife. :ROFLMAO:
I’ll checked them out thanks!
1 - 20 of 43 Posts
