1 - 2 of 2 Posts
I had no problem replacing the camshaft oil seal and o-ring but the distributor's seems to be stuck, and good. Any tips? Simply popping it out had no result. I then tried the self tapping sheet metal screws at opposite sides and vice grips method, but the screws just ripped free. I don't want to mar the surrounding metal so I thought I'd ask for suggestions.
Amy ideas?
Discussion Starter #2
Never mind. Heat, tapping, pulling, eventual structural integrity failure, removed.
And FYI your 44mm thin walled socket for the crank nut is the perfect size for a race to tap in the new seal.
Now to figure out how to torque down the camshaft and dizzy nuts.
1 - 2 of 2 Posts
