Hi Guys,
Whilst stripping my engine and looking at the timing gears/sprockets etc i noticed even though the gears do not have the normal hook wear pattern, they are all very rough on the edges.
I had already planned to replace the upper and lower timing chains but i am concerned about the state of these gears.
Is it normal practice to smooth these edges with a metal file etc. or would these gears need to be replaced ???
Thanks for any help.
Rob.
Richard Jemison
Sprockets
At a minimum I suggest smoothing them out.
The critical wear area on the crank and intermediate sprocket is the borrom surface od each notch.
If wear is nor excessive when assembled with a new lower chain the "teeth" of the two sprockets will clear each other about .010. If more you will have some 'slop" with the new chain.
An issue? Probably not a great one as within 5 hours of run time the chain will have lengthened to a longer lasting "set" but continue to grow as miles pile up.
Discussion Starter · #4 ·
Thanks for the responses guys.
Richard, when you say "at a minimum i suggest smoothing them out, i am curious as to what else could be done. Could you please elaborate ?
Rob.
Richard Jemison
Sprockets
Of course!
Replacement, but simply smmothing the machined edges with a round file and shot blasting should leave them polished looking.
Richard can make them like this for you.....
