Water pump is off correct?
If you have removed all the little nuts and the water pump and the crank pulley....you should be ready. Use a block of wood and hammer and start tapping around the perimeter. It'll be stuck on there and will need a little help to get started. Once you get it going...just keep it level coming off or it'll hand on the studs. Be careful and mindful of where you are placing that wood for hammering. Keep to the edges. Don't want to break out the casting by beating down the middle of the cover.
Best Regards,
John M
Best Regards,
John M
