Over time the timing chain will stretch. Personally I have never seen one break, but I am sure they will. When you check the tension on the chain, it you think the tension has to pushed out more each time, it's probably time to purchase a new chain.
You can get the cheap italian one, but the german made chains seem to be much better and worth the money. Spruell in Atlanta stocks the german chain.
The change out is very easy. Remove cam cover and rotate engine until link is at the top and engine at TDC. Place a towel under the chain between the cam sprockets to keep you from dropping the links in the sump. De-tension the chain and lock into place. Remove links and use two pieces of wire or coat hanger to hold onto the chain. use old link and connect old chain to the new chain on the intake side. Feed the chain through until you get the new chain all the way in. Use new links, re-tension and your done.
Good luck.
Good luck.
