Help!
Sound like a rattle at 3000 rpm from engine. 1974 spider. Figured I should check the timing chain tension but after loosening the tensioner lock nut one complete turn the chain tensioner doesn't budge in either direction. Seems to be jammed and can't pry it out to tighten the chain. There is a groove in the timing chain cover on the driver side but I wonder if this might be old.
Anyway, any suggestions would be welcomed. I am as stuck as the tensioner at this stage. Not sure how much force can be applied to make it shift. Am I missing something here?
The engine was recently rebuilt by a good machine shop here in seattle.
Thanks for any suggestions
Ts
Ts
