Hi,
NEVER EVER push hard the motor if it hasn't reached the normal temperature... Revving hard a cold motor is a very nice way to end its life.
Now the normal temp for a IE boxer engine is around 82-85 C. I think it is high time you had the thermostat replaced.
Regarding the noise: is the tone of the noise a metal one? can you isolate it and determine where it comes from?
If the noise advances with the revs then for sure it has to do with a moving part. Can be a failing water pump, a worn alternator/tensioner bearing or a worse case scenario like a big end bearing...
Regards,
Regards,
