161 - 180 of 197 Posts
Discussion Starter #162
Thanks Bill ....Those cylinders needed a lot of scrubbing to get rid machining grit. Got the rods installed on the new pistons and replaced the Goetze rings with Hastings. All piston rod assemblies within a gram, manual calls for 4 grams max deviation.
1636380
Epoxy painted studs done. Wait a week or two before assembling.
1636376
1636377
Discussion Starter #163
Ready to assemble with new valves, might as well not that they were bad.
1636649
Just to show how Lodge look in the combustion chamber vs Bosch W7DTC and Eyquem RFC 58 LS3.
I've used Lodge, but the others work.
1636650
1636651
1636652
Reactions: markivan
Discussion Starter #165
1636807
1636808
1636809
Of course the size you need is not the one you have.....bought 8 new ones!
Reactions: markivan
Discussion Starter #166
Valves adjusted, got them at 19 and 21 so I put the head aside and started to assemble the bottom end.
Std bearing shells, GOETZE brand, thrust bearings and the cigarette seals with a dab of silicone in the corners of the rear cap.
1637850
Torqued to 35 ft-lbs. Spins freely
1637851
8
Discussion Starter #167
Cylinders in and pistons installed today.
1637997
Took me 3hrs to install the pistons. Slow process.
1637999
I'm in awe of you guys that have the skills to take on these rebuilds! I just love watching and learning.
Discussion Starter #170
Thanks....It's just the tip of the iceberg, you don't see is all the work behind the scene.
Discussion Starter #171
1638467
Installing front cover, averted disaster with correct gasket. Two different oil passage way locations, wrong gasket will cover it.
1638469
Don't forget the oil slinger.
1638470
A little elboew grease applied to the sump.
1638471
ok
Reactions: markivan
I've been reading a lot about oil pump failures recently. I assume you have checked yours spins happily after being installed :)
Discussion Starter #173
Thanks for the tip, yep made sure it spins freely. Took it and the by pass apart and it was v clean inside. I think the failure point is probably the roll pin for the drive gear. Didn't do anything with it though.
Reactions: markivan
Discussion Starter #175
Can you spot the two anomalies in this picture. One is subtle and the other one is obvious !
1638473
Reactions: markivan
What rotor is that?
To check the oil pump fit, install with bolts just less than snug. Turn over a couple times. Tighten bolts a bit. Stick big screwdriver into oil pump drive dog, where dist drive fits. Can you turn it a bit, just a bit of gear backlash? If so, good, tighten down bolts. If no backlash wiggle and try again.
Discussion Starter #177
Andrew, exactly what i did. Finger tight, turn it a few, tighten some more , repeat. Have not checked for backlash though, good tip! Thanks.
Oh yeah, the rotor is easy, but what else??? Hint; its related.
The rotor is a poor mans rev limiter.
It is marked 6500. Centrifugal force grounds the spark.
Early Porsche 930 turbo rotor,
1638476
drops right in!
Reactions: markivan
Points replaced?
Discussion Starter #179
Yeah but that's not it...very warm!
1300 water pump pulley?
Those rev-limiter rotors are genius. Have had a few on German cars.
