241 - 260 of 265 Posts
Discussion Starter #241
1652208
Original from 1964 and new. Original was beige.
1652209
1652210
Original worksmanship, was sewn.
1652214
As a test I carefully cut the tubing off all the way around the door seal and now the door closes perfectly.
Thinking of making my own ....
1652215
For reference, I'll send this sketch to Cicognani. Not expecting much though.
Reactions: Sergio105
Be aware that the original is over 40 years old so would have lost it's shape by now
Great sketch BTW!
Reactions: ganunez
Discussion Starter #244
Great sketch BTW!
Yes, the tube has turned into an oval.
I have the exact same problem with the doors on my 66 Super and these seals. I know its not the on door seals for me as I used 4 NOS seals. I think I might have to try the trim approach too. I was going to just but the later rubber ones but from reading a previous post it looks like they are wrong too...:(
Hi George, on my white Giulia, the one residing in San Diego, owned by Avid test now, I used velvet rubbers from the UK, the number 81 doorseal. Furflex Door Seals - Draught excluders
I saw no noticeable difference with the original rubber, and together with repro on door rubbers the doors shut really nice.
Price was quite a bit less as with the usual suspects.
Best,
JC
1652639
Discussion Starter #247
1652641
Big THANKS JC, that looks great. I will order it.
I did find McMaster Carr has one that works but only in black plastic. Need 45 feet to do all doors. I installed it for now, but I do want the beige velvet.
1652642
The McMaster strip fits 3/16 edge with 3/8 tube. Would have been perfect if flocked.
Discussion Starter #248
1652643
For the time being....backup until Furflex arrives.
Discussion Starter #250
1653186
1653187
1653188
1653189
Need a reliable plating shop, preferably in Florida. Anybody ??????
The original grill needs some dings removed and plating.
Reactions: 1750GT
Discussion Starter #253
Yes it's slightly magnetic so stainless!
But after lightly sanding some greenish corrosion it's copper looking in the area of the slats. So i don't know what's going on.
Photo?
Discussion Starter #255
1653716
1653717
After sanding with 400 and seeing green on the sandpaper.
I took my grill to a polishing shop, they called me 30 minutes later: “we can’t do anything with this, it’s chromed”. Apparently only later ones are stainless and early ones chromed...
Excellent progress by the way, comming together nicely!
Reactions: JCDK
In 2013 in Padua I bought the 5-piece grill you see in the picture from Eric Thijs. It is one of the first and is in chromed brass. This one I took is obviously to be chromed ...
Discussion Starter #258
Ready for a drive....of course had to clean the DCOE 27s inside.
Oil p just over 55 , water at 175, and no grille.
Idles smoothly.
1653946
Original plenum base hiding under those filters, with a custom plate on top....or something else?
Discussion Starter #260
You got it
