1 - 10 of 10 Posts
Hi guys,
I have read every thread concerning sprark plugs. My engine is 1600cc.
Am i buying the NGK BP7ES or the B7ES??
I know that the BP7ES has the extended tip, so my question is that would it be appropriate for the 1600cc engine or would the tip can endanger hurting the pistons somehow?
1966-2013
The ES won't hit the pistons, or at least are no more likely to than the valves will get into them.
You'll get a slightly better flame front with them too as it puts the spark deeper in the chamber.
1966-2013
That's the valve hitting the plug, which can happen.
The question was would it hit a piston :)
Indexing will cure/prevent the valve to plug issue.
I've been on ES and other brand extended tips for several years now and haven't had one get whacked by a valve yet, even with 11mm cams. (but I index as a regular habit)
Yesterday I checked the sparkplugs my car had on. They were the BP6ES. Maybe a bit too hot as a sparkplug? In any case, I already purchased the BP7ES. So I am only changing the heat in here...no difference in the extended tip. :)
I use the BP6ES in all my cars below with no problems. I think the 7 is too hot for extended driving. Also, I doubt the valve of a 1600 will get anywhere near the plug tip. Although as Tifosi says, it never hurts to index them.
7 is colder than 6, not hotter.
Ed Prytherch
"do you have oversized valves? high lift cams?"
yes and yes.
but as that is a common thing to do on a 4 cyl Alfa you never know what one has.
if you did not do it the PO might have etc. but it came to a shock to me when that happened. and it could have dammaged/jammed the valve. and that would be game over.
1 - 10 of 10 Posts
