Anyone know where i can find one? I'm having no luck with IAP and Centerline...
I tested my speedo by putting my drill on the end of the upper speedo cable and it works great. The upper cable is new, so that leaves the sending unit, the lower cable, or the input gear. After many searches on this forum it seems the most likely culprit is the input gear.
Symptoms: On startup speedo works fine... within 2 blocks it's reading low and bouncing... within 2 miles it won't go over 25mph regardless of speed.
Anyone know if the input gear can be swapped without pulling tranny?
Thanks in advance for any help.
