That's the question, which exhaust is the best for this motor? The coversion 1.7 16V into Sprint went well, and now I want power as much as posible without turbo.It will be a street every day muscled car not verry loud but not normal too :eek:.At the moment it is low 16 at 1/4 mile, but I want it faster.Help me please :)
its simple...standard or custom slightly larger extractors (cross over if you want to be fancy) centre hotdog and for the rear a 1 in 2 out muffler (or however you want it to look on the back) all joined up with 2in to 2 1/4in pipe...go stainless if you want it to last forever and look good.
This is what i did for mine 33:
primary pipes 42mm diameter - lenght 58cm
secondary pipes 54mm - lenght 40 cm
and 60mm all the way to the end with 80mm dtm style ending
I did two mufflers filled with stainles steel sponges
Car has lost his boxer sound because of crossover exhaust, but it revs happily and goes very well :D
I have loads of pictures if you need some information.
This is the headers off a p4.
The actually seem to collect in the same place as a normal set of 16v
headers.
