Hey all , after reading through the post regarding brake bleeds, it seems my best bet is to jack the *** end up super high, bleed the fronts with no ignition, then bleed the rears with ignition on, useing half pedal pressure to bleed.
if all else fails , what are the chances that the MC would fail. If it is faulty is the buick reatta MC the best match or do i have more options IE what cars used the teves mkII ABS system please.
also any tips or prep tips you can give me before i attempt this job.
car is 87 milano verde with ABS, rotors , calipers and pads are new, cant get a good pedal.
Thanks in advance,
LW
The brake MC in ABS cars is hugely different than the non abs cars. It is hugely painful to remove and extremely expensive new OR used.
if it ever came to a ABS MC issue in my own car the brakes would be converted to conventional brakes without ever looking back. The ABS MC unit itself is probably $1500.00 new (if you can find it) and at least a few hundred from most wreckers. Also, even though the Teves MKII system is the same in other domestics (and import cars), the only non-interchangeable part is the valve assembly (MC)...youll need one from a verde...
luckily the same is not true of most of the other components :)
Cars using the Teves Mark II ABS (4-wheel, Integral system)
The TEVES MARK 2 ABS (4-wheel, Integral) system was used on ABS versions of the following cars. If you surf around enthusiast sites for the different cars you can pick up a lot of information and may stumble across something useful.
Autozone has a lot of online information on the Ford/Lincoln system. Most of it should cross over.
Also check out this article from the St Louis club.
Debugging the Milano/75 ABS System
1985 to 1989 Lincoln Continental
1985 to 1992 Lincoln Mark VII
1986 to 1989 Buick LeSabre
1986 to 1990 Buick Electra, Park Avenue
1986 to 1989 Cadillac Fleetwood Brougham
1986 to 1990 Cadillac DeVille
1986 to 1990 Oldsmobile 98
1986 to 1990 Pontiac 6000 STE
1987 to 1992 Ford Thunderbird
1987 to 1992 Mercury Cougar
1987 to 1993 Saab 9000
1988 to 1989 Cadillac Eldorado, Seville
1988 to 1989 Buick Reatta, Riviera
1988 to 1989 Merkur Scorpio
1988 to 1990 Oldsmobile Delta 88, Toronado
1988 to 1991 Peugeot 505
1988 to 1990 Pontiac Bonneville & SSE
1991 to 1993 Saab 900
1991 to 1993 Volkswagen Passat
cool thanks guys i will be reading for awhile.
