The $29.90 oil-filled Saab mount
2127 Views 12 Replies 8 Participants Last post by  Alfissimo Int.
I was quoted a high price (US$300+) for the ubiquitous front engine mount (suspect on my 164) so I did a few searches here instead, as I remembered talk of Saab 9000 mounts long ago on 164Discussions.
As mentioned in Alfisto Steve's post here http://www.alfabb.com/bb/forums/showpost.php?p=122355&postcount=1 long ago, here is a likely-looking candidate for the lower-front engine mount. This is not the solid one that people have used with success. http://www.eeuroparts.com/(iaaadbeivsoltm55ihzhrh55)/productdetail.aspx?searchResults=1&code=5599
I notice the price is now a bargain $29.90, it says it is hydraulic, looks to be a suitable height and does not have metal plates etc. on top, and so the only problem is that the stud is too big in diameter.
I think I would be happy to remove A/C compressor and alternator so as to unbolt engine mount bracket from engine and drill out hole to suit, particularly since after all this I would still have the refinement of an oil-filled mount as Alfa Romeo envisaged.
So, another job to add to the list ;)
-Alex
1 - 13 of 13 Posts
Looks like you would just have to saw off the two tabs and maybe the stud is not too big. Seems like it might be the right size. If you order one, would you let us know how it works out? I have the solid Saab mount and it's working fine but some have had it give out prematurely.
Charles
Charles
Alfisto Steve pointed out it was too big in diameter, and he actually had them all side-by-side in the post I just added the link for :) so it's a certainty that something would have to be drilled out.
Yes - I thought that for the price, I will order one and give it a whirl... now, let's hope they take credit cards...
-Alex
OK, Gotcha. Seems like a removal of the compressor would be inevitable replacing the mount anyway, so drilling out the aluminum mount would be easy enough after that. ;)
Charles
Having some failing mounts here, I bought a Saab hydraulic mount _and_ an AR mount (they can be had much lower than $300 here). I compared them and decided that the Saab mount height would be proper if one made a spacer to fit around the tabs. The stud on the Saab unit is (I think) a 12mm thread instead of the 10mm thread on the AR. I considered two options on the stud:
1) belt-sanding the threads off and re-threading the smaller stud, and buying a 10mm (maybe adjustable) die and threading the stud. It might not be absolutely necessary to remove the other threads if an adjustable die opens up enough.
2) drilling out the A/C bracket. The standard clearance hole for a 10mm thread is 11mm, and a 12mm hole might actually pass the 12mm stud. If you _had_ to retrofit back to the AR stud, a bushing could be made and maybe fixed in place with red Loctite.
I've had the suggestion made that sawing off the Saab stud and drilling/tapping the hole for a 10mm bolt would be a Good Thing. I was too nervous about drilling into the oil-filled region.
And, as often happens with the plans of men, events pushed me and I had to install the AR mount on the car. I haven't had time to pursue the Saab mods, but they are still under consideration. I rather favor the belt-sander/die combination. The spacer disk may not be a good idea if it stresses the hydraulic mount and causes it to fail.
By the way, Charles, it is not at all necessary to remove the A/C mount. You just have to loosen the subframe bolts and pry the subframe down to make clearance for installing the new mount. The old one is usually in two pieces and comes out with no problem.
Michael
I'm doing the same thing with my rebuild. I had to pay $75 for mine which I considered to be a bargain, but I guess not anymore :eek: I buy a lot of these kind of odds and ends at rayce auto parts online.
Sean, the solid mount is a newer version of the Saab 9000 part and it sells for about your $75 price. The older-style hydraulic ones seem to be in low demand (I think that's the reason for the low price), and I thought I'd check it out but haven't finished that process.
Michael
I'd be curious to know how much cabin vibrations increase when the solid mount is installed.
Quite a few have installed the solid Saab mount and have not reported a change in cabin vibrations. I've not noticed any change.
The solid mount just needs the extra flange ground off, and when repainted, looks just like the original except it takes a bolt instead of having a stud sticking out. Takes a certain length bolt, but I bought several for when the dealer installed it. He first thought it was a new OEM, as it looked and fit just right in the LS, using one of the bolts I supplied.
It is one of the earlier Saab solid mounts, however, so may have to change it one of these days for the newer higher quality and longer lasting version.
My solid Saab mount does not seem to be holding up well. The rubber is breaking up. I would recommend stating with the Alfa mount.
3
Yup. I agree. They are not very good. I stopped modifying these about a year or so ago due to them failing faster than stock.
I have some stock ones coming in September for a very good price. I can bet lower than most.
The saab mount modified can raise the motor about 1/4- 1/2" in the front. You cut anymore down in the mount and there are no threads left.
They fit better, less vibration, better quality! The stud goes all the way through the mount as well. We only get 1/4 way through the solid mount.
All said and done I may have them in about 2-3 weeks for around $199+/-
Saab mounts run about $130 (corteco) for the good ones. There are some crappy after market ones running around that fall apart. I have replaced mine once already as it ripped out.
My suggestion don't bother. You get what you pay for. You will be replacing it again and again.
The hydraulic filled mount is in low demand for a reason, upgraded to the solid which is not much better. Alfa OEM is much better quality than the saab and in the past years the Alfa mount has been upgraded.
$29.99
This is the one I use to modify:$128
OEM: $199.00 my price
I think there is a reason for the mount to be filled with hydraulic fluid! Most of the time when they go bad it is because the upper torque mounts are weak or the rear mount is weak or broken. Then it pulls on the front mount and weakens it. I don't suggest the cheapy $29 route, I think they are made in China, solid corteco are German. OEM is made in Italy of course.
Just my advice.
Ciao!
Jason
Sorted then, Jason... I know you'd do an overseas-sale just for me ;) Maybe I could pay you with Paypal or something.
In the meantime I got as far as shining a flashlight around the a/c compressor and getting that off looks like fun, fun, fun until Alex takes the engine away. How the hell it fits out past the coolant pipes etc. I just don't know. The reason for removal of bracket was theoretically to drill out hole to accept larger mounting stud but really, I think now this is a bad idea. :)
And anyway - while shining the flashlight around, I realised that the engine mount in question looks clean and dry - and when I raised the engine a little with a jack, the mount shows no signs of undue movement. So there's probably nothing wrong with it after all that, and my slight knocks/movement in the gearshift (with engine torque) are probably something else, like the rear mount perhaps (as I apply power after a gearchange, I can feel the gearlever move slightly).
There's also a lot of torque steer effects, a bit scary at 'high' speed, but I think those are probably control arm bushes, as they're covered in oil and sorry-looking.
Cheers,
-Alex
Cheers,
-Alex
Sounds like linkage bushings bad. Somethings the linkage bushing which has a plastic sleeve can slip off and mis align the arm. Check them all.
Check upper torque rod bushings I bet they are bad especially front small one.
If those are bad you can get some of those issues. I would not count on the Transmission bushing to be bad, they seem to be the best ones alfa makes. I have never replaced one.
The rear passenger might be an issue. Also this seems stupid but I had a clunk very similar and the mount bolts where ever so slightly loose and the engine slipped back and forth and created a clunk at take off and sometimes when stopping really hard.
But now if you say bushings are covered in oil, that is the problem. I have seen that 100 times over. That oil eats them up and makes them slip.
I have a ton of those bushings coming in Sept. as well. They are inexpensive. No need to buy the whole arm.
I bet your hydraulic tensioner is leaking? Do you have the HT still? If so. Keep it and rebuilt it every timing belt change.
Good luck Alex.
Jason
1 - 13 of 13 Posts
