Problem: 1991 Spider, driving home from a road trip, hesitation at throttle tip in, warm engine, half tank of fuel. However, little or very brief hesitation, if one becomes aggressive on throttle from a standing start. Also becomes difficult to start, with intermittent rough idle. By the way, none of these symptoms were evident with a full tank of fuel.
In the driveway, the Check Engine light illuminated briefly twice whilst trying to hold 2,000 rpm (she was running raggedly, with rpm fluctuating). Pulled a 1223 code.
1223 Code Troubleshooting:
1. Check to ensure there are no intake duct air leaks
2. Check the air filter for proper functioning
3. Check to ensure fuel pressure is correct
4. Check the electric injectors and airflow meter for proper functioning
Examining under the hood, I found the fuel pressure regulator vacuum line torn open on the underside at the regulator, out of sight from any casual visual inspection. Replaced the hose, and on a hunch, tried to directly power the in-tank fuel boost pump from the battery. No joy. So, new pump on the way. Will advise as to results.
