Is there a trick for testing my speedo and tach while they are out of the car? I tried installing an old cable and attaching it to a drill motor and tried putting a square tip bit directly into the back. I was afraid to spin the drill motor very fast but none of my guages did anything ( and I even have an extra set so two speedos and two tachs).
Am I doing something wrong? Should it go clockwise or counter clockwise?
Also, is it possible to get new chrome rings?
Certified Oldschooler
If you want to really pump that resto cost up to $50k, Palo Alto Speedometer will make them better than new. Did my 69 Spider gauges there, all 5.
I do what you're trying. Run gently both ways to see. I don't think you'll hurt it at slow rpm. I don't recall which way they turn, but seems like it would be the way the needles more (clockwise viewed from the front).
I recently replaced my tacho cable and before hooking up the engine-end, I tested it with a power drill. Unfortunately I tested it with the drill in "forward" first, which yielded no indication from the tacho. I then changed the drill to "reverse" and that produced a positive reading on the tacho. It's been in the car now for several months and seems to have suffered no ill effects.
