Piston to liner question
Sent: 3/30/2019 9:47:04 AM Central Standard TimeSubject: Re: piston to liner
I`m glad you ask! That`s a poor response from CA or Cosworth who ever suggested that.
First, piston clearance in the liners should never exceed .004.-.005" and that is a bit looser than most road race engines are built. If the engine was being built for long runs at max RPMs where serious heat growth is expected, in excess of typical Road Race use (Turbo/supercharged/Bonneville and such), much less street driving, then clearances must be tighter. to control piston movement that reduces ring seal.
Cast pistons (like stock) should be happy at about .0025". But Forged pistons an a street motor set at .003" should have a long life. (that`s where I would clearance them) The Ross pistons (Forged Racing pistons) in the new race motor are clearanced at .0035".The measurement of the piston that should be used is the diameter of the skirt below the piston pin half way to the skirt bottom. (The piston top is generally as much as .020 smaller due to heat absorption growth.)Be sure the upper 2 rings are gapped correctly. Typically .004 per inch of bore for both top & 2nd ring. New 2nd ring designs are set with more gap than old design 2nd rings.
Rj
From: [email protected]: rmsabinsr/Cc: [email protected]In a message dated 3/29/2019 6:08:52 PM Central Standard Time, [email protected] writes:Hi Richard, Mike Sabin here. The cams are great, no questions there. I would appreciate your thoughts on piston to liner clearance. I have the Classic Alfa forged pistons made by Cosworth. I asked them what the clearance should be and they said to just bore the liners to 84.5 and I’d be good. That sounded kinda goofy to me but what do I know. The pistons are 3.306 inches and 84.5mm is 3.326. That is twenty which would be .010 thousandths piston to wall. That seems pretty loose for a street motor. What do you think?Thank you I really appreciate your help.MikeMichael Sabin
Rj
