I don't know the year of your spider, but usually the cause is from a bad ground or bad connection either at the tach itself or at the coil, now is the time break out the wet/dry sandpaper and start cleaning terminals;)
· Administrator
The cable is the likely problem. If it gets kinked/worn it tends to bind/release over & over again making the needle jump around. You can try undoing one end of the cable (usually at the tach end), sliding out the inner cable, cleaning it and re-greasing it. Dribble a few drops of oil into the outer sheath and slide the inner cable back in place. If you are lucky that might fix it. But if you see broken strands or a kink in the inner cable replace the whole thing.
